Hi Nick,
Hmmm.
Are you shure you did the following two steps?
1.3 See chapter 5.2 Install Eclipse update of ‘Getting Started with Kinetis SDK (KSDK)’ document located in KSDK installation path: C:\Freescale\KSDK_1.1.0\doc\Getting Started with Kinetis SDK (KSDK).pdf
1.4 Verify that ‘KSDK_PATH’ environment variable is set correctly. See ‘Appendix B’ in this document
I've always tossed in a re-boot after doing this.
David
