BUG: sporadic CMSIS-DAP errors "Failed to read memory"
davenadler
Senior Contributor I
Latest KDS with all updates as of yesterday, using Freedom K64F board (and its built-in debugger).
While debugging any and all projects, the console window sporadically reports
Failed to read memory errors:
Is there a fix planned for this bug?
Thanks!
Best Regards, Dave
Tags (2)
Hello Dave,
Recommend you use the latest version of KDSv3.2,  please download it at here :
Kinetis Design Studio Integrated Development Environment (IDE)|NXP
If after you re-install the KDS, it still have this problem, please tell me how to reproduce it,
this problem happen on any project or a specified one , could you please test a simple project .
Alice
davenadler
Alice_Yang wrote: Recommend you use the latest version of KDSv3.2,  please download it at here :
What does the first sentence of the bug report say? It says:
Did you even bother to read the report?
Alice_Yang wrote:  If after you re-install the KDS, it still have this problem, please tell me how to reproduce it,
this problem happen on any project or a specified one...
Did you learn how to do support from Microsoft, where a standard answer is "Re-install Windows" ?
No, I am not going to re-install KDS every time I report a bug. Are you trying to drive away customers?
Alice_Yang wrote: ... this problem happen on any project or a specified one , could you please test a simple project
What does it say above? Obviously you did not bother to read it. It says:
While debugging any and all projects, the console window sporadically reports...
On complex or trivial projects I regularly see this error pop up.
Please forward this bug report to someone who is able to read it and provide an answer!
Thanks, Best Regards, Dave
Hello Dave,
Sorry for the inconvenient to you .
Maybe i have not put it clearly .
As i  use the FRDM-K64 board , the OpenOCD debug interface , KDSv3.2 , test one hello world
project , it can work well , have not the error you report.   So i tried to know how your error generated.
Please see the Console view show on my side :
If it really a bug,  yes, I'm surely report it to the related team, first i need to know how to reproduce the error .
If you have test a simple project , it still show this error , could you please change a new KDS workspace or
delete the ".metadata" folder under KDS workspace folder , then have a  try .
Alice
