ADC with multi-channel works and DMA
2,324 次查看
hanchengyang
Hello everyone,
I am working on a project which needs take care of many analog inputs, now I am using the the stupid method : configure to channel X -> wait for interrupt -> change to next channel ...
Is there any example that ADC refreshes certain array frequently without interrupting CPU ??
YANG Hancheng
2,093 次查看
DavidS
Hi YANG Hancheng,
We don not have specific example for your environment but there is good appnote that goes over using DMA for reading many ADC channel's.
http://cache.freescale.com/files/32bit/doc/app_note/AN4590.pdf
David
4 回复数
2,093 次查看
hanchengyang
I forgot to mention that I am using KDS 3.0.1 with PEx.
2,094 次查看
DavidS
Hi YANG Hancheng,
David
2,092 次查看
hanchengyang
Thanks a lot, I have just successfully configured DMA in ProcessorExpert for 12 channels continuous sampling with the help of your application note. Maybe I will wrote a guide for others.
Hancheng
2,092 次查看
DavidS
Hi Hancheng,
Congratulations on your efforts!
If you have time to document (and/or share) I am sure others would appreciate and learn from it.
David
