In some application, we hope one project can support multiple targets. Some typical examples: user needs different firmware to run on different PCB with different crystal on it; Or sometimes user needs one project support both debug and release mode; another widely used example is, user needs one project support multiple part numbers.etc.
To implement the multiple targets project, we will consider at least three aspects:
In this article I will discuss this topic with Classic CodeWarrior and Eclipse CodeWarrior10.x/KDS separately.
Original Attachment has been moved to: Multi-Targets-Project_Classic-CW-HCS12-v5_1.zip
Original Attachment has been moved to: Multi-Targets-Project_KDS-v3_2.zip
Sometimes macro is enabled, but the editor still shows it grayed out. See solution here:
