Hello community!
This document explains how to link the CMSIS-DSP library to a KSDK 2.x project in KDS.
The steps described in the document were done using the MK64FN1M0VLL12 MCU like the one in the FRDM-K64F board, but the same principles are applicable to any Kinetis MCU.
Software versions
The steps described in this document are valid for the following versions of the software tools:
Contents
1. Glossary.
2. Overview and concepts.
2.1 CMSIS - Cortex Microcontroller Software Interface Standard.
2.1.1 CMSIS Components.
3. DSP example application.
3.1 Creating KSDK 2.x Project.
3.2 Linking CMSIS-DSP Library.
3.2 Importing DSP example source files.
Appendix A - References.
I hope you can benefit from this post, if you have questions please let me know.
Best Regards!
Carlos Mendoza
I have been trying to link the CMSIS DSP lib to my MK24F project in KDS version 3.0. I am using KSDK version 1.3.0.
I was so glad to have found the instruction provided here. It looked like it should have worked. However, I still have the same error
after implemented the steps provided in the pdf file.
c:/freescale/kds_v3/toolchain/bin/../lib/gcc/arm-none-eabi/4.8.4/../../../../arm-none-eabi/bin/ld.exe: cannot find -llibarm_cortexM4lf_math.a
collect2.exe: error: ld returned 1 exit status
makefile:116: recipe for target 'mk24f.elf' failed
make: *** [mk24f.elf] Error 1
I checked the make sure I was using the '/' instead of the '\' and pasted the path in the file explorer to verify that it was correct.
Any idea why the ld.exe was not able to find the lib file?
Thank you,
Ron
Hi Ron,
The same steps apply with a KSDK 1.3 project. Please make sure that you use the library name "arm_cortexM4lf_math", the name should not include the ‘lib’ prefix and ‘.a’ suffix:
Hope it helps!
Carlos Mendoza
Technical Support Engineer
