I referred to the datasheet as well as the reference manual, but haven't come across a space in memory dedicated to storing user data.
i there such memory space available? or should we be using external EEPROM?
thank you, will check
A block of Flash can emulate EEPROM if it is for rarely changed configuration data.Otherwise add external EEPROM.
