is there a user data memory space available in K32L2B11VFM0A
847 次查看
Luzvi-S
I referred to the datasheet as well as the reference manual, but haven't come across a space in memory dedicated to storing user data.
i there such memory space available? or should we be using external EEPROM?
780 次查看
Luzvi-S
thank you, will check
804 次查看
bobpaddock
Senior Contributor III
A block of Flash can emulate EEPROM if it is for rarely changed configuration data.
Otherwise add external EEPROM.
