Hello @bobpaddock ,
Thank you for your reply.
After the ROM bootloader is started, how do you program it? Do you use blhost? What is the return after entering the following command?
blhost --port COMx -d -- get-property 1
The usage of blhost: MCUBLHOSTUG.pdf
I understand that it is inconvenient for you to send the KL27 file through the community channel. You may submit a private case and describe your problem, and engineer will reply and provide related resource by email.
Please follow up below steps to submit a case
1. go to SUPPORTHOME, click on "Submit a Ticket" in the middle of this page.
Support | NXP Semiconductors
2.Login, Or Register with your business email
I hope it will help.
BRs,
Celeste
