Errata e9308 K32L2B11VLH0A mask 1N71K
massimoincerti
A customer stumbled into the errata e9308 on the K32L2B11VLH0A MCU, it is about I2C and for technical reasons related to the project (use of DMA channels already allocated to other sources) the customer cannot apply the suggested workaround.
Is there any new silicon mask planned for the part that could in case address this issue?
Attached the errata document.
Thanks and best regards
Massimo
