CAN Read_only_mode
CAN Read_only_mode
260 次查看
Tau
I am currently using the S32K144. I would like to know how to set the CAN read_only_mode. Also, I want to know why I can’t receive bus messages under the read_only_mode.
239 次查看
PetrS
refer to Listen Only Mode, set by CRTL1[LOM] bit. In this mode more nodes must be connected to the bus as messages not acknowledged is not received in LOM mode.
BR, Petr
240 次查看
PetrS
BR, Petr
234 次查看
Tau
so,if I have only one node, I can not use this mode
