I have build my drone but there is a beep sound coming from the FMU. I am not sure what the error is can anyone share the url of the beep sound error meaning or the meaning of blinking lights.
Solved! Go to Solution.
The beep heard is probably because you still have a USB cable attached. Another possible beep means that there is no SDCARD inserted. This was a new beep feature that was added.
