Today when I was testing the autolanding and auto takeoff one of the propeller loosened up and evetually fell off and result in drone flipping and crashing.
Solved! Go to Solution.
If using normal self-tightening propellers this should not happen. If using properllers with nuts, it is possible that a motor is spinning the incorrect direction such that it unthreads the nut.
