OK, so I got a new FlySky from NXP and the sticks work on this one. Second issue I am having is that when I try to calibrate the the radio in QCGroundControl I get "Detected 0 Channels. To operate PX4 you need at least 5 channels." Anyone else get this. I feel like I have followed all the instructions and the radio is successfully bound, the channels on the radio are mapped. Any ideas?
Solved! Go to Solution.
Double checking - did you set the RADIO TX to i.bus output ? That - on power up - programs the RX to go into iBUS/SBUS output mode: https://nxp.gitbook.io/hovergames/userguide/radio-controller-setup#setting-the-output-mode-2.
