Preset Widgets Usage
1,006 次查看
sajithdevidas
I created a customized widget, and i save into the presets,  how can i share my preset collection with another pc, where will it get stored if i added a custom widget to the presets?
and how can i add more presets into my presets collection via externally?
958 次查看
LiubinGong
Hi @sajithdevidas
    You can find the custom style config file at the following location:
win10:
%appdata%\\gui-guider\\{version}\\preset_record.setting
Ubuntu:
~/.config/gui-guider/{version}/preset_record.setting
MacOS:
~/Library/Application Support/gui-guider/{version}/preset_record.setting
The current version does not support the import and export of preset style, We will add this feature in a later release.
Best Regards
Liubin
