Gui Guider1.4.1滑动页和菜单控件使用问题
huenrong
1. 使用Gui Guider1.4.1中的滑动页控件时, 新增页面后, 页面之间切换不方便, 有时候无法切换
2. 使用Gui Guider1.4.1中的菜单控件时, 无法新增子菜单
3. 部分控件无法添加事件, 比如图像和文本框控件无法添加事件
ZhangJennie
HI @huenrong
In order resolve your issue, please provide us more information:
1. Did you find the same problem in previous GUI Guider versions? or this issue is only in Gui Guider1.4.1?
2. Please provide screenshots or video for the problem.
I will check this problem as soon as I get your feedback.
Thanks for your cooperation.
Best Regards
Jennie
qizhipeng
我遇到了同样的问题选项卡部件下无法再添加部件,只能修改名称
