freemaster
freemaster
1,184 次查看
song123
Why is the "pig in module" drop-down menu blank?
1,155 次查看
MichalH
NXP Apps Support
NXP Apps Support
this seems as a problem of installation - it must be run with administrator rights.
You can easily fix it by running the C:\NXP\FreeMASTER 3.2\FreeMASTER\register.bat as an administrator (select the file in Windows Explorer, pull a context menu and select "Run as administrator").
If this does not help, re-start the installer also with administrator rights.
Michal
1,142 次查看
song123
Thanks, this is very useful
1,106 次查看
MichalH
NXP Apps Support
NXP Apps Support
Thanks. If this solves your issue, please mark this and the other question as resolved.
Michal
