Speed deviation
Speed deviation
1,089 次查看
zhouqicheng
Using the official routine, the phase current frequency was measured at 25000 rpm, and it was found that the speed exceeded 200 rpm. When asked how to reduce it, freemaster was used, and the expected speed was consistent with the actual speed
1,001 次查看
victormarcel09
  1. The type of system you're working with (e.g., industrial machinery, automotive, robotics).
  2. The specific component or device whose speed you were adjusting.
  3. Any error messages or issues you encountered before using freemaster. TellPopeyes
  4. The steps you took within the freemaster tool to align the expected speed with the actual speed.
