I use mtrdevkspnk144 platform to develop motor control system. I want to control motor speed through freemaster variable. In the PMSM_appfreemaster_TSA. H or freemaster_TSA. H file, which variable stores the target speed of the motor transmitted by freemaster?
解決済! 解決策の投稿を見る。
Dear customer,
Rotor speed can be controlled through FreeMASTER variable "Speed Required".
Dear customer,
Thinks for your help!
Dear customer,
this question is not related so much to FreeMASTER as it is a general tool and framework for runtime visualization and control of embedded applications. I will try to redirect the question to author of the Mtrdevkspnk144 application.
