hi, I am working with FreeMaster and with S32K116 EVB board . It can not works perfectly, I get lot of error 0x80000101.could you tell me what wrong it is?thanks
Hi @D_pengF,
0x80000101 is the error code for Timeout (meaning the PC dis not receive a reply from the target board in a specified interval).
Do you get this error instantly (when trying to connect) or after a while using FreeMASTER ?
