ubloc wifi driver for linux error "moal: Unknown symbol pci_save_state (err -2)" ?
1,390件の閲覧回数
Da_123456_DA
I hope this is the right location :
I'm trying to run this nxp driver :
nxp/wifi_mod_para.conf
but I get this errors:
modprobe moal mod_para=nxp/wifi_mod_para.conf
moal: Unknown symbol cfg80211_sched_scan_results (err -2)
moal: Unknown symbol cfg80211_mgmt_tx_status_ext (err -2)
moal: Unknown symbol cfg80211_rx_assoc_resp (err -2)
moal: Unknown symbol regulatory_set_wiphy_regd_sync (err -2)
moal: Unknown symbol pci_request_region (err -2)
moal: Unknown symbol pci_enable_device (err -2)
moal: Unknown symbol cfg80211_scan_done (err -2)
moal: Unknown symbol cfg80211_sched_scan_stopped (err -2)
moal: Unknown symbol pci_iomap (err -2)
moal: Unknown symbol pci_choose_state (err -2)
moal: Unknown symbol cfg80211_remain_on_channel_expired (err -2)
moal: Unknown symbol cfg80211_cac_event (err -2)
moal: Unknown symbol cfg80211_register_netdevice (err -2)
moal: Unknown symbol __pci_register_driver (err -2)
moal: Unknown symbol regulatory_hint (err -2)
moal: Unknown symbol pci_set_power_state (err -2)
moal: Unknown symbol cfg80211_new_sta (err -2)
moal: Unknown symbol cfg80211_disconnected (err -2)
moal: Unknown symbol pci_unregister_driver (err -2)
moal: Unknown symbol pci_read_config_dword (err -2)
moal: Unknown symbol wiphy_new_nm (err -2)
moal: Unknown symbol cfg80211_ready_on_channel (err -2)
moal: Unknown symbol cfg80211_classify8021d (err -2)
moal: Unknown symbol cfg80211_rx_mlme_mgmt (err -2)
moal: Unknown symbol wiphy_register (err -2)
moal: Unknown symbol __cfg80211_alloc_reply_skb (err -2)
moal: Unknown symbol __cfg80211_alloc_event_skb (err -2)
moal: Unknown symbol cfg80211_put_bss (err -2)
moal: Unknown symbol cfg80211_roamed (err -2)
moal: Unknown symbol cfg80211_ch_switch_notify (err -2)
moal: Unknown symbol ieee80211_get_channel_khz (err -2)
moal: Unknown symbol __cfg80211_radar_event (err -2)
moal: Unknown symbol cfg80211_tdls_oper_request (err -2)
moal: Unknown symbol cfg80211_find_elem_match (err -2)
moal: Unknown symbol __cfg80211_send_event_skb (err -2)
moal: Unknown symbol cfg80211_michael_mic_failure (err -2)
moal: Unknown symbol wiphy_apply_custom_regulatory (err -2)
moal: Unknown symbol cfg80211_del_sta_sinfo (err -2)
moal: Unknown symbol wiphy_unregister (err -2)
moal: Unknown symbol cfg80211_get_bss (err -2)
moal: Unknown symbol pci_iounmap (err -2)
moal: Unknown symbol pci_restore_state (err -2)
moal: Unknown symbol ieee80211_freq_khz_to_channel (err -2)
moal: Unknown symbol cfg80211_pmksa_candidate_notify (err -2)
moal: Unknown symbol cfg80211_vendor_cmd_reply (err -2)
moal: Unknown symbol pci_set_master (err -2)
moal: Unknown symbol pci_reset_function (err -2)
moal: Unknown symbol cfg80211_unregister_wdev (err -2)
moal: Unknown symbol pci_enable_wake (err -2)
moal: Unknown symbol cfg80211_rx_mgmt_ext (err -2)
moal: Unknown symbol ieee80211_channel_to_freq_khz (err -2)
moal: Unknown symbol ieee80211_hdrlen (err -2)
moal: Unknown symbol cfg80211_report_wowlan_wakeup (err -2)
moal: Unknown symbol cfg80211_ft_event (err -2)
moal: Unknown symbol pci_disable_device (err -2)
moal: Unknown symbol cfg80211_inform_bss_data (err -2)
moal: Unknown symbol ieee80211_bss_get_elem (err -2)
moal: Unknown symbol pci_release_region (err -2)
moal: Unknown symbol cfg80211_connect_done (err -2)
moal: Unknown symbol cfg80211_unlink_bss (err -2)
moal: Unknown symbol wiphy_free (err -2)
moal: Unknown symbol cfg80211_cqm_rssi_notify (err -2)
moal: Unknown symbol cfg80211_auth_timeout (err -2)
modprobe: can't load module moal (extra/moal.ko): unknown symbol in module, or unknown parameter
using 6.1.22-linux4microchip-2023.04
this works for me 4 months ago~ , but I needed to rebuild the linux
 I compare the linux.config from 4 months ago to what I have now - seem the same
what is the problem ?
can someone guide me ?
this allowed in the config:
CONFIG_CFG80211=y
CONFIG_CFG80211_DEBUGFS=y
CONFIG_CFG80211_WEXT=y
CONFIG_MAC80211=y
CONFIG_BRCMFMAC=y
CONFIG_MWIFIEX=y
CONFIG_MWIFIEX_SDIO=y
CONFIG_MWIFIEX_PCIE=m
CONFIG_MWIFIEX_USB=m
CONFIG_MWL8K=y
CONFIG_WILC_SDIO=y
what else is missing ?
google\chatgpt\gemini all say something is wrong with CFG80211 - but I don't see anything change
Thanks ,
0 返答(返信)
