how to generate srecord format for PowerPC architecture when using Diab compiler?
1,359件の閲覧回数
Ehsan1
Hi.
I am writing a bootloader for mpc5746b microcontroller. Compiler that I am using is Diab. It generates an elf file as output object format. However what I need is s-record format. Although in "https://www.windriver.com/themes/Windriver/pdf/PN_Compiler_0110.pdf" it is mentioned that Diab compiler can generate s-record format, I have not found any linker option for Diab for this goal.
If Diab supports generating s-record format for PowerPC architecture , what is its linker option?
if it dose not support, is there any way to convert elf  to s-record ?
Thank you for your help in advance.
0 返答(返信)
