Failed to enable "/dev/spidev0.0" to access spi flash from the userspace
DeepakHM
Hi ,
I am trying to create spidev entry in /dev/ by adding the device tree node under qspi node but the device is not showing up in /dev/ can you please help me to get it.
The below is the device tree node I added.
&qspi {
        status = "okay";
        mt25qu512a0: flash@0 {
                compatible = "jedec,spi-nor";
                #address-cells = <1>;
                #size-cells = <1>;
                spi-max-frequency = <50000000>;
                spi-rx-bus-width = <4>;
                spi-tx-bus-width = <1>;
                reg = <0>;
                partition@0 {
                        label = "u-boot-spl";
                        reg = <0x0 0x4000000>;
                        read-only;
                partition@1 {
                        label = "test";
                        reg = <0x400 0000 0x100000>;
    spidev@0{
        compatible = "spidev";
        reg = <0>;
The below are the dmesg logs.
root@localhost:~# dmesg | grep "spi"
[    2.418536] spi-nor spi0.0: mt25qu512a (65536 Kbytes)
[    2.423615] 1550000.spi-0: error parsing ofpart partition /soc/spi@1550000/flash@0/partition@1 (/soc/spi@1550000/flash@0)
[    2.437915] fsl-quadspi 1550000.spi: chipselect 0 already in use
[    2.443933] spi_master spi0: spi_device register error /soc/spi@1550000/spidev@0
[    2.451339] spi_master spi0: Failed to create SPI device for /soc/spi@1550000/spidev@0
root@localhost:~#
Deepak H M
