What is the size of RDDRONE-BMS772?
Search instead for
Donghyun
What is the specifc frame size of RDDRONE-BMS772?
iaingalloway
Thanks!
Since it is for development, It's designed to be able to zip-tie strap permanently to a LiPo battery that is typiclaly 3-4S 4000-5000mAh
One could also make a 3d printed case for the board and battery.
seongyooncho
It's 48 mm x 90.5 mm.
