Solved! Go to Solution.
Hello Glennarguil,
The MC... mark means the MCU is mask independent for the specified type (S12XEP100).
The S...W1... mark means exact mask defined by W1 (mask set & revision).
The detail information about marking is in Reference Manual on:
https://www.nxp.com/docs/en/data-sheet/MC9S12XEP100RMV1.pdf - Ordering information.
The clock frequency can be determined from RM / Chapter 11 also. It is valid for both mentioned marked devices.
If you need more help, you are welcome.
Stano.
Hello Glennarguil,
Stano.
Thanks Stano. for the help
