MC56F8365 bootloader
496件の閲覧回数
ethanxiang
newbee on this chip, could anyone tell me how to generate a bootloader for it ?
Thanks a lot !!
タグ(2)
345件の閲覧回数
dynapb
If you have not found this info yet there is a bootloader factory installed in the chip.  The following is info from the manual.  I use the 8367 and use the UART bootloader all the time.
4.8 Factory Programmed Memory
The Boot Flash memory block is programmed during manufacturing with a default Serial Bootloader
program. The Serial Bootloader application can be used to load a user application into the Program and
Data Flash (NOT available in the 56F8165) memories of the device. The 56F83xx SCI/CAN Bootloader
User Manual (MC56F83xxBLUM) provides detailed information on this firmware. An application note,
Production Flash Programming (AN1973), details how the Serial Bootloader program can be used to
perform production Flash programming of the on-board Flash memories, as well as other potential
methods.
Like all the Flash memory blocks the Boot Flash can be erased and programmed by the user. The Serial
Bootloader application is programmed as an aid to the end user, but is not required to be used or maintained
in the Boot Flash memory.
Pete
