HI
Does the IRQB pin of MC33816 need to be connected to a pull-up resistor? I did not find the hardware circuit about IRQB pin in the data sheet
thanks
You can directly use it as output without pull up!
In your application, does IRQB configurate as input or output?
HI IRQB configurate as output. Thanks
