How can I trigger the ADC12 with a Timer? I Can't find the dubious SYNC1 signal. (MC56F84769)
andreasvogt
The manual says:   Use a SYNC1 input pulse or CTRL2[START1] bit to initiate a B converter parallel scan.
So what is SYNC1, a input pin, a interprocess signal and where can I find it?
xiangjun_rong
Hi,Andreas
As
admin
Specialist II
Hi Andreas,
SYNC1 is a input of the ADC Module and you can map several signals to this input by using XBAR.
=> Map XBAR Input of your timer you like to use to XBAR output of ADC trigger
