Dataseet saf7730
Dataseet saf7730
4,895 次查看
lysyhaleksandr
Hello! I can’t find a datasheet for saf 7730 anywhere! Can anyone have information?
4 回复数
4,811 次查看
guoweisun
This product had already EOL now!
4,011 次查看
Nickldio
I also need the datasheet for the SAF7730HV, I found one for the SAF7741. Are they similar enough to work with that instead? I'm looking for the I2C registers to switch the input to SPDIF.
4,388 次查看
galaxy_110
Also I need a datasheet of saf7730
4,582 次查看
Dunconi
I would be grateful if a datasheet for the SAF7730HV/233 were to be made available. I appreciate that the part is EOL, but there is still equipment in the field that requires servicing and repair. I would be surprised if this request was blocked on the grounds of IP when the part is EOL and was designed around 15-years ago.
