Clock generation in CAN bus devices
2,065 次查看
rknispel
I am looking for details of the clock generation in UJA1169ATK/F:
  • clock source
  • PLL
  • Jitter in 13 bit interval of CAN communications
Is there a technology papaer where it can be derived from?
1,995 次查看
rknispel
The question was transferred into a service case and resolved there.
6 回复数
1,996 次查看
rknispel
2,046 次查看
guoweisun
What kinds of clock detail information do you need?
2,044 次查看
rknispel
My questionnaire is about details of the Automotive qualification of the CAN communications of UJA1169ATK/F:
CAN network clock source
PLL frequency [MHz]
max. PLL jitter in 13 bit interval
oscillator manufacturer
oscillator part name
oscillator frequency [MHz]
oscillator tolerance [%]
Possible answers include clock recovery from CANH/CANL lines, and the oscillator would be MCU oscillator.
2,026 次查看
guoweisun
These parameters should be checked or setting in CAN controller side,right?UJA1169 is CAN transceiver.
2,020 次查看
rknispel
The parameters are relevant for reliabilty of CAN communications in on-board network as Automotive application. UJA1169 is considered for SBC of such a component.
Typically the internal clock is generated from TXD by clock recovery. I am looking for more details on this process!
Help is very much appreciated and thanks for any hints in advance!
2,060 次查看
rknispel
The data sheet says "microcontrollerindependent clock source" is present on the chip, but where can further details be taken from?
