About MC33816 Vboost
Showing results forย
Search instead forย
Did you mean:ย
1334769096
I used the MC33816 IDE build the code for MC33816, but however I changed the Vboost voltage, from 24V to 65V. The Vboost always up to almost 80V, then the chip be broken. The mean is I can't control it. Can you help me?
Thanks!
zflailfh
I also encountered the same problem, I can't control the Vboost๏ผŒso I had to use a voltage regulator to protect the MC33816 from damageใ€‚
Does anyone know of a solution to this problem๏ผŸ
1334769096
Yep! I resolved it
zflailfh
How did you solve it? (=^ ^=)
1334769096
Other configurations is default, The MC33816 IDE version is 2.3.1.0
guoweisun
Which kind of board do you test on? EVB or your own design board?
1334769096
my own design board, The schematic refers to the official demo.  And I wanna know If I used the default configurations on MC33816 IDE, Can I direct to test the board?
guoweisun
Suggest you test in EVB firstly,even if the default setting the Vboost can't up to 80V because of the maximum value is about 72V.
