connect and disconnect
1,521 次查看
jonasb
I wan't the board to auto connect to a server. Then he try's to autoconnect to the server for 18 times.
Then he gives an error that there is no memory left. I was searching and i
found he did an alloc. So he makes a reservation for some memory 18
times. I think i have to do something with free my memory. I found
something like TCB_FREE. I tried somethings but i still get acces
error.
another question:
How do I try to restart connection (sync) when the connection is closed by the server? The board seems to block.
And I have no clue how to solve it.
Please help me
837 次查看
jdog
you just have to work with m_delsocket(so) but you have to place this code somewhere where the socket is not used any more then you can delete it else you will get a acces error.
I think you have to place it somewhere in tcpapi.c
838 次查看
jdog
