Using CW for ColdFire v.6.4, target MCF5307, assembly error: "Illegal relocatable".
1,395 次查看
Veter
I have this simple statement in my os_cpu_a.s file:
TER0 .equ ___MBAR+0x151
It seems quite legal but compiler throws exception bellow:
Error   : Illegal relocatable expression
os_cpu_a.s line 161   TER0 .equ ___MBAR+0x151
I'm quite sure the answer is very simple I just can't find any info in the help files.
Can anyone please give me a hint what I'm I missing here?
700 次查看
SimonMarsden_de
The CodeWarrior assembler only supports equates which can be fully resolved at assembly time. I think that a lot of assemblers work this way.
You can achieve the effect that you want by using a .textequ directive:
TER0:     .textequ "___MBAR+0x151"
When the assembler encounters the symbol TER0 in the source code, it will substitute the string __MBAR+0x151 (Like #define in the C preprocessor).
Hope this helps
Simon
