Hi Marc,
Thanks for the links to the code. Also thanks for letting me know about what to be careful about while using the Interniche stack. What I need to do is much simpler than using the functionalities of the complete stack. For now, I just need to be able to send a packet from one board to the other and vice-versa. Later I intend to build on this. I figure I need to learn how to work the FEC for this. Two specific questions :
Which files (in the stack patched by you) do I have to look at to be able to achieve this simple task, and which won't be necessary to look at?
How to run this code on my board?
