Stopping the build...
708 次查看
bobw
For CodeWarrior 10, how does one stop the build after just some number of errors? I would think there is a setting somewhere for this......
I have too many errors in the build and I'd like to see the first occurance (which is causing all others). However, the console buffer has overflowed....
341 次查看
CrasyCat
Specialist III
Hello
I am not aware of any way to stop building after the first error, but you can increase size of the build console.
This can be done as follows:
  - Open the Workspace Preference dialog (select Windows -> Preferences"
  - Select page "C/C++" -> "Build Console"
  - Increase size of "Limit Console output (# lines)"
  - Click OK to validate the change
You should be able to see more messages now.
I hope this helps a bit.
CrasyCat
