The BGA's LS1043AXN8PQB have some default on balls after soldering : deformation and voids
Do you have information on the same problem of warpage for other customers ?
Do you have special recommandations to avoid the warpage of this type of BGA without overmolding on the die ?
Thank you
"LS1043AXN8PQB"? That's "QorIQ, 4xCPU 64-Bit ARM Arch":
LS1043AXN8PQB Product Information|NXP
That's about as far from a Coldfire chip as you can get!
Please MOVE (option on edit somewhere) this post to a "place" where you're more likely to get an answer.
Tom
