I am wondering if ECR[ETH_ENABLE] must be set in order to generate MII management frames, and what happens when ECR[ETH_ENABLE] is toggled on/off during communication with an attached PHY device? Also, what happens if the FEC is reset during communication with an attached PHY device?
One last thing, the user manual refers to an "MII_STATUS register" in one spot. What is that exactly?
Mike
