MCF52235 QSPI with no delays between transmissions
2,306件の閲覧回数
ariaveta
I would like to know if I can setup the Coldfire MCF5223 QSPI in master mode to have no clock delays between subsequent data.
The best result I got was about 1 clock delay. I'm asking this because I plan to use the QSPI not to transfer data to a slave device but to generate precise waveform without worrying about interrupt.
Any suggestion will be appreciated.
Marco
2 返答(返信)
1,073件の閲覧回数
Petter
Does your waveform data fit in the FIFO? If it does I guess you could just use the wrap mode and disable interrupts.
1,073件の閲覧回数
ariaveta
Hello Petter,
 thanks for your reply.
I can't use wraparound mode because the waveform has a finite duration and I have to generate it at random time.
Bye,
Marco
