I have tried to compile the P&E drivers for Ubuntu 7.10 using the P&E website downloaded version ( it has the nessesary device drivers in the tarball )
You will have to include an ancient header (ioctl32.h) in the library path, but still no luck. Header and output is attached.
John Ulyate
