M52277EVB - Linux P&E driver (pe_driver_ver_324_811.tar.gz) will not compile
Jaux
I am trying to compile and install the P&E BDM driver in LTIB under SuSE Linux rev 10.3
1. The tarball from the distribution differs from that from P&E's web site, even though it has the same version numbers - pe_driver_ver_324_811.tar.gz
2. README refer to libstc++ to be above level 6 - what is this?
3. Running sh setup.sh fails on the makefile - a couple of missing header files.
Can anybody point me in the right direction?
Much appreciated
John Ulyate
Jaux
I have tried to compile the P&E drivers for Ubuntu 7.10 using the P&E website downloaded version ( it has the nessesary device drivers in the tarball )
You will have to include an ancient header (ioctl32.h) in the library path, but still no luck. Header and output is attached.
John Ulyate
