JM Badge Board Applications - small mistake
AndreiBoeru
I found a little mistake in the demo Applications. In the file accelerometer.c starting from line 486, the original code is:
switch(sensitivity)
    case Range15g:
      PTCD_PTCD4 = 0;
      PTCD_PTCD5 = 0;
      break;
    case Range2g:
      PTCD_PTCD4 = 0;
      PTCD_PTCD5 = 1;
      break;
    case Range4g:
      PTCD_PTCD4 = 1;
      PTCD_PTCD5 = 0;
      break;
    case Range6g:
      PTCD_PTCD4 = 1;
      PTCD_PTCD5 = 1;
      break;
    default:
      PTCD_PTCD4 = 0;
      PTCD_PTCD5 = 0;
      break;
The problem is that Range2g and Range4g are misplaced. So the correct code would be
switch(sensitivity)
    case Range15g:
      PTCD_PTCD4 = 0;
      PTCD_PTCD5 = 0;
      break;
    case Range4g:
      PTCD_PTCD4 = 0;
      PTCD_PTCD5 = 1;
      break;
    case Range2g:
      PTCD_PTCD4 = 1;
      PTCD_PTCD5 = 0;
      break;
    case Range6g:
      PTCD_PTCD4 = 1;
      PTCD_PTCD5 = 1;
      break;
    default:
      PTCD_PTCD4 = 0;
      PTCD_PTCD5 = 0;
      break;
Happy coding!
Message Edited by Andrei Boeru on 2008-12-27 01:00 AM
anthony_huereca
Thanks for catching that! The change will be uploaded to the website soon.
