You can install SonarLint in Eclipse, but you don't know how to install SonarLint in cw_mcu_v11.1_b181224_PE.
How to download and install SonarLint in cw_mCU_v11.1_b181224_PE IDE?
The MCU I use is MCP52259, and I want to do static code scanning in Sonatqube. I wonder whether the compiler of this MCU is supported?
Hi, @wwj ,
As I see SonarLit is external plugin, you can install SonarLint from the Eclipse Marketplace and read the official SonarLint documentation.
As S32DS is using eclipse platform, you can use eclipse plugin supported accordingly.
Thank you. Best regards.
- Mehul Patel
