I need the documentation that describes voltage levels and timing for all the signals on the 68EN360.
Did you look in Chapter 10 of the User manual?
That's the top one in the "Reference Manual" section on the Product Page.
http://www.nxp.com/assets/documents/data/en/reference-manuals/MC68360UM.pdf
What Manual were you looking in?
Tom
Thank You,
We have looked at this section, is there any other documentation available outside of the user’s manual detailing timing/voltage levels/power?
Trent Foster
Field Applications Engineer
Avnet Electronics Marketing
trent.foster@avnet.com<mailto:trent.foster@avnet.com>
10808 S. Riverfront Pkwy – Suite 392
South Jordan UT 84095
801-365-3765
First you stated in the Subject "That info is not in the user's manual".
That info is in the User's Manual. All 85 PAGES of "Section 10, Electrical Characteristics".
Lots of sections give AC Timing for the Bus, SPI, Timer, SI., SCC, SMC, DMA, PIO and so on.
Section 10.5 gives the "DC Electrical Specifications" (Voltage levels)
Sections 10.3 and 10.6 give Power.
Motorola/Freescale's later documents put the register descriptions in the "User Manual" and the electrical characteristics in the "Data Sheet", but back in the 1990's (this product dates from 1993, the User Manual from 1998) they put everything in the one document. On PAPER.
That's as good as it gets. I don't think there are any other documents.
If you need something else you're going to have to detail exactly what you need to know and also detail where the User manual is lacking.
You're from Avnet, so I guess you're trying to answer a customer query. Maybe you should post the technical contents of that query.
Tom
Thanks for the clarification, I don’t believe we had the complete user’s manual so this will help. I worked for Motorola for several years an am very familiar with the data books they used to have for all of their processors.
Trent Foster
801-365-3765
