How to make M54455EVB linux support UART 2?
1,946件の閲覧回数
mikeqin
hi,
I found that M54455EVB linux source only support uart 0 and 1. I am trying to make it support uart 2. I did following modification in drivers/serial/mcfserial.c:
- add "console=ttyS2" to the uboot bootargs.
- change .. (mcfrs_console_port ? MCFUART_BASE2 : MCFUART_BASE1));
to (mcfrs_console_port ? MCFUART_BASE3 : MCFUART_BASE1));
Still not working, any thoughts on this?
Mike
1,373件の閲覧回数
mikeqin
The problem is solved now, after changing the init value of the mcfrs_console structure :smileywink:
