How to disable BDM clock output
1,334 次查看
Stefou
Hello everybody,
I am looking to:
How can I disable the PSTCLK output from a CF5373L. I have many problems on radiated field emission with this approximately 117MHz clock.
We use this clock to synchronize the ColdFire with the WindRiver pod to debug this.
THANK YOU
645 次查看
PaoloRenzo
Try to change to JTAG mode using JTAG_EN. That should disable the clockout pin. If this is not enough try to use LIMP mode to reduce emissions.
