Help me Newbie
Help me Newbie
1,613 次查看
RajMacOSX
Hi All,
I am very new for code warrior. I have installed it on my Machintosh and try to learn it. I have created a new project in it and try to compile it. Everything is fine but only froblem with the below error:
CANN'T LOAD OBJECT DATA FOR FILR 'CRT1.O'
In fact this file is showing in my project. I want any document which deals with step by step creation of a new project.
Please tell me what shuld I will have to resolve my problem.
rajajihai
805 次查看
J2MEJediMaster
Specialist I
Do the example Codewarrior projects work?
You say you see the file, but is it part of the build target? Check to see if the file name in the project window has a little black dot in the column with a target at the top.
---Tom
805 次查看
RajMacOSX
Hi Tom
Yes, you are right. It shows black dots.
RajMacOSX
