Flasher for MCF5233
Flasher for MCF5233
1,004 次查看
Jana1
Dear Community,
I am a little bit at loss at the moment.
As I have to change the bootloader of a MCF5233, I am currently searching for a Flasher for this controller.
I tried the CodeWarrior Version 11.1, but there the controller is not included in the Flash Programmer. Then I tried to install the Version 7.2, but there I would have to install a Virtual Machine for a 32 bit System.
Has anyone any suggestions on what else I could try?
Thank you so much!
994 次查看
Hui_Ma
P&E company provide PROG Flash programming software (PROG-HL-CFZ), which also support program ColdFire chip with external NOR Flash. More detailed info, please check here. This software supports WIN10/11 64-bit.
Wish it helps.
Mike
