DEMO baord reboots when ethernet connect/disconnect with TCP/IP lite stack, why?
已解决
跳至解决方案
1,507 次查看
TVNAIDU
I loaded CF TCP/IP stack, everytime when I connect/disconnect  ethernetm board reboots, does TCP/IP stack not stable?.
 .....COULD NOT ESTABLISH LINK.....
Running ColdFire TCP/IP-Lite stack Revision 3.1
Copyright 2008 by Freescale Semiconductor Inc.
Use of this software is controlled by the agreement
found in the project LICENSE.H file.
Built on Sep 29 2009 14:15:32
IP Address  = C0A80064 -> 192.168.0.100
Mask        = FFFFFF00 -> 255.255.255.0
Gateway     = C0A80001 -> 192.168.0.1
InterNiche ColdFireLite TCP/IP for ColdFire, v3.0
Copyright 1997-2006 by InterNiche Technologies.
All rights reserved.
Preparing device for networking
Ethernet started on Iface: 0
INET>
INET>
INET>
INET>
INET>
INET>
INET>
INET>
100bT - Half Dup
INET>
100bT - Half Dup
INET>
100bT - Half Dup
INET>
INET>
INET>
INET>
INET>
INET>
INET>
INET>
INET>
INET>
INET>
INET>
INET>
INET>
INET>
INET>
INET>
INET>
INET>
100bT - Half Dup
INET>
INET>
INET>
INET>
标签 (1)
1 解答
840 次查看
vier_kuifjes
Senior Contributor I
See my reply in your other thread...
在原帖中查看解决方案
1 回复
841 次查看
vier_kuifjes
