I don't have an answer,
I have the same question, but for a different processor
need to know what the absolute negative resistance value (Rs) for DSP56F803?
Need this value to select an alternative 8Mhz crystal oscillator, ESR=100, without load caps.
need to verify Rs is at least 500 ohms
The Driver circuit inside the processor is what determines the negative resistance not the crystal supplier.
The NXT/Freescale Semi datasheets and manuals for this part to not mention or show this value.
Can anyone help with this?
