C Macro with asm
C Macro with asm
3,832 次查看
Nouchi
Senior Contributor II
here's my C macro
Code:
volatile uint32 myVar;#define myMACRO() asm {\  TST.L myVar\  BEQ LABEL\  ADD.L %-1,myVar\LABEL:\   }
I would like to know how to to genarate unique label each time the macro is used, I tried "\@" after label name but it doesn't work.
What's the right syntax ?
tahnks
1,495 次查看
Nouchi
Hi, The right syntax is in the header files: Code:
extern volatile uint32 myVar;inline asm void myFunction(void){  TST.L myVar  BEQ LABEL  ADD.L %-1,myVarLABEL:}#define myMACRO() myFunction()
Emmanuel,
4 回复数
1,495 次查看
ynaught
I don't know what your compiler is, but GCC has a Very Useful Feature that allows silliness like:
 TST.L myVar\
 BEQ 1f\
 ADD.L %-1,myVar\
1:\
It appears in this case to search forward ( indicated by the 'f' ) for the next label 1:  ... I really like this in that it frees you from coming up with unique labels for landing points within subroutines, which you'd never call from outside.
I have NO IDEA if other compilers allow this.
1,495 次查看
Nouchi
Sorry, I forgot to mention that it was CodeWarrior 6.3 for ColdFire.
I think that CW documentation isn't clear enough about asm macro.
This kind of feature seems only works with in lined asm function in CodeWarrior.
Emmanuel
1,496 次查看
Nouchi
Emmanuel,
1,495 次查看
Nouchi
Somebody has an idea ?
Can I use branch relative instructions inside C macro ?
Emmanuel
Message Edited by BugMan on 2006-10-2504:02 PM
