Availability of M53015EVB Schematics
2,029 次查看
ReeL
Does anyone know where I might be able to get a copy of the schematics for the M53015EVB?  I would like to check the details of its features before committing to buy one.
1,207 次查看
Dec
5 回复数
1,207 次查看
admin
Specialist II
I would like also to check some details concerning dual phy layers. Could you share a copy of the schematics of the M53015EVB if you keep it? I'll be appreciated!
1,207 次查看
ReeL
I still have a copy but can't upload it with this response sorry.  If you go to the downloads page for the M53015EVB you will find a download called "M53015EVB - Printed Circuit Board bill of materials and design files: Available files and documentation for printed circuit board manufacturing".  This contains a PDF of the schematics - and other things.
1,208 次查看
Dec
This one ?
1,207 次查看
ReeL
Thanks Dec,
Yes it looks like the one I was after.  Thank-you :smileyhappy:
I saw your post of https://community.freescale.com/message/66796#66796 We are looking at using the LQFP for a design too so I have added a question for you there.
Thanks again
1,207 次查看
J2MEJediMaster
Specialist I
The closest thing I have found is the M53015EVBUM User Manual, which has a block diagram of the board. The manual does not have schematics, however.
---Tom
An error has occurred when reading existing sub-variable "Language_PG_Configuration"; see cause exception! The type of the containing value was: extended_hash+string (lithium.coreapi.webui.template.models.NamedValueByNameTemplateModel wrapped into f.e.b.StringModel) ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign redirect_lingo_page_url = web... [in template "language_macro_header.ftl" at line 173, column 1] - Reached through: #include "language_macro_header.ftl" [in template "Language_translator_Dashboard" at line 3, column 1] ----
